メインコンテンツにスキップ
Dell Inspiron 15 3567 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 15 3567 Battery Replacement, Sliding the Battery Latch: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Slide the battery-release latch to the unlocked position.
    • You hear a click sound when the battery is unlocked.
  2. Dell Inspiron 15 3567 Battery Replacement, Lifting the Battery: 手順 2、 1の画像 1
    • Using your fingertips, lift the battery at an angle and remove it from the battery bay.
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  3. Dell Inspiron 15 3567 Battery Replacement, Placing the Battery: 手順 5、 1の画像 1
    • Place the battery in the battery bay and snap the NEW battery into place.
ゴール
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Terrence15
メンバー登録日: 12/18/17
79,585 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
1件のガイドコメント
I'm a tech savvy user but, I just read this just to be sure there wasn't anything I was missing. I didn't think of grounding the system board for some reason. Thanks for that! Critical step!
David D - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 24
過去 30 日: 86
今までの合計 3,557
