メインコンテンツにスキップ
Dell Inspiron 15 3567 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron 15 3567 Display Assembly Replacement, Remove the Screws: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  2. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Display Hinges: 手順 2、 1の画像 1
    • Open the display hinges to an angle of 90 degrees.
  3. Dell Inspiron 15 3567 Display Assembly Replacement, Peel the Tape: 手順 3、 1の画像 1
    • Peel the tape that secures the display cable to the palm-rest assembly.
  4. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Latch: 手順 4、 1の画像 1
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 15 3567 Display Assembly Replacement, Note the Display Cable: 手順 5、 1の画像 1
    • Note the display cable routing and remove the display cable from the routing guides on the palm-rest assembly.
  6. Dell Inspiron 15 3567 Display Assembly Replacement, Note the Antenna Cable: 手順 6、 1の画像 1
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  7. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Palm Rest Assembly: 手順 7、 1の画像 1
    • Open the palm-rest assembly at an angle and slide it off the display assembly.
  8. Dell Inspiron 15 3567 Display Assembly Replacement, Placing the Display Assembly: 手順 8、 1の画像 1
    • Place the NEW display assembly on a clean, flat surface.
  9. Dell Inspiron 15 3567 Display Assembly Replacement, Placing the Palm-Rest Assembly: 手順 9、 1の画像 1
    • Place the palm-rest assembly on the display assembly.
  10. Dell Inspiron 15 3567 Display Assembly Replacement, Close the Display Hinges: 手順 10、 1の画像 1
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  11. Dell Inspiron 15 3567 Display Assembly Replacement, Replace the Screws: 手順 11、 1の画像 1
    • Replace the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  12. Dell Inspiron 15 3567 Display Assembly Replacement, Route the Antenna Cables: 手順 12、 1の画像 1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  13. Dell Inspiron 15 3567 Display Assembly Replacement, Connecting the Display Cable: 手順 13、 1の画像 1
    • Connect the display cable and close the latch to secure the cable.
  14. Dell Inspiron 15 3567 Display Assembly Replacement, Route the Display Cable: 手順 14、 1の画像 1
    • Route the display cable through the routing guides on the palm-rest assembly.
  15. Dell Inspiron 15 3567 Display Assembly Replacement, Adhere the Tape: 手順 15、 1の画像 1
    • Adhere the tape that secures the display cable to the palm-rest assembly.
    • Close the display and turn the computer over.
ゴール
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,585 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 34
今までの合計 2,984
