はじめに
In this guide, we will be showing you how to remove and replace the Memory Module.
Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
もう少しです!
ゴール
ある他の人がこのガイドを完成しました。
