メインコンテンツにスキップ
Dell Inspiron 15 3559 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron 15 3559 Hard Drive Replacement, Remove the Screws: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15 3559 Hard Drive Replacement, Lifting the Latch: 手順 2、 2の画像 1 Dell Inspiron 15 3559 Hard Drive Replacement, Lifting the Latch: 手順 2、 2の画像 2
    • Lift the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 15 3559 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 手順 3、 1の画像 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 15 3559 Hard Drive Replacement, Disconnecting the Interposer: 手順 4、 1の画像 1
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 15 3559 Hard Drive Replacement, Remove the Screws: 手順 5、 1の画像 1
    • Remove the screws that secure the hard-drive bracket to the hard drive and lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15 3559 Hard Drive Replacement, Placing the Hard Drive: 手順 6、 2の画像 1 Dell Inspiron 15 3559 Hard Drive Replacement, Placing the Hard Drive: 手順 6、 2の画像 2
    • Place the hard-drive bracket over the NEW hard drive and align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  7. Dell Inspiron 15 3559 Hard Drive Replacement, Replace the Screws: 手順 7、 1の画像 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 3559 Hard Drive Replacement, Sliding the Hard-Drive Assembly: 手順 8、 2の画像 1 Dell Inspiron 15 3559 Hard Drive Replacement, Sliding the Hard-Drive Assembly: 手順 8、 2の画像 2
    • Slide the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  9. Dell Inspiron 15 3559 Hard Drive Replacement, Replace the Screws: 手順 9、 1の画像 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,555 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 1,218
