はじめに
The is laptop received a new hard drive and a memory module exchange. Straight forward replacement with no surprises.
パーツ
パーツは指定されていません。
  1. Here is a Dell Inspiron 14z N411z that is going to get a new memory module. On the back side is only one cover for the hard drive as well as the memory module. Remove the Phillips screw on the bottom right corner of the cover.
    • Here is a Dell Inspiron 14z N411z that is going to get a new memory module.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  3. Use a plastic opening tool to unsnap the cover from the back case. Move the tool gently along the corner of the cover. The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come of.
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come of.
  4. Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up With the securing clips spread, the memory module will pop up. Remove the memory module and replace as needed.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
    • With the securing clips spread, the memory module will pop up.
    • Remove the memory module and replace as needed.
まとめ
ある他の人がこのガイドを完成しました。
oldturkey03
メンバー登録日: 2010年09月29日
577,560 ポイント
101のガイドは作成済み
チーム
OTS OTS人のメンバー
Business
1 メンバー
127のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,685
