はじめに
Hello, this guide will inform you how to remove the hard drive from your Dell Inspiron 14R-5421.
Before working on your device, remember the electrostatic discharge (ESD) safety procedures before fixing your device.
Removing your hard drive is faster and easier than one may think, so I would recommend putting aside a least 5 minutes in your day to complete this guide.
If you need to remove a hard, you may have issues with hardware damage or failure, resulting in overheating, system crashes, and file corruption among other things.
If you have read this far, then you have just completed one of the first steps in solving a problem, which is to identify a solution, so proceed with the below steps.
必要な工具と部品
ある他の人がこのガイドを完成しました。
