メインコンテンツにスキップ
Dell Inspiron 14R Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron 14R Display Assembly Replacement, Remove the Screws: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws from the computer base.
  2. Dell Inspiron 14R Display Assembly Replacement, Loosen the Cable: 手順 2、 1の画像 1
    • Loosen the display cable grounding screw.
  3. Dell Inspiron 14R Display Assembly Replacement, Disconnect the Display Cable: 手順 3、 1の画像 1
    • Disconnect the display cable from the connector on the system board.
  4. Dell Inspiron 14R Display Assembly Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Remove the four screws that secure the display assembly to the computer base.
  5. Dell Inspiron 14R Display Assembly Replacement, Lifting the Display Assembly: 手順 5、 1の画像 1
    • Lift the display assembly off the computer base.
  6. Dell Inspiron 14R Display Assembly Replacement, Place the Display Assembly: 手順 6、 1の画像 1
    • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  7. Dell Inspiron 14R Display Assembly Replacement, Routing the Cable: 手順 7、 1の画像 1
    • Route the display cable and Mini-Card antenna cables through the routing guides.
  8. Dell Inspiron 14R Display Assembly Replacement, Connect the Display Cable: 手順 8、 1の画像 1
    • Connect the display cable to the connector on the system board.
  9. Dell Inspiron 14R Display Assembly Replacement, Tighten the Grounding Screw: 手順 9、 1の画像 1
    • Tighten the display cable grounding screw.
  10. Dell Inspiron 14R Display Assembly Replacement, Replace the Screws: 手順 10、 1の画像 1
    • Replace the two screws at the bottom of the computer.
ゴール
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,522 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 257
