はじめに
In this guide, we will be showing you how to remove and replace the Hard Drive.
必要な工具と部品
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Align the notch in the module edge connector with the tab in the connector slot.
Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
もう少しです!
ゴール
ある他の人がこのガイドを完成しました。
