はじめに
if the speaker is not playing sounds properly or liquid is spilled into the speaker gap in the frame of your laptop it is easy and simple to replace them.
必要な工具と部品
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
