はじめに
The Cooling fan is used to remove heat from the laptop so it is not hot to the touch and does not burn the motherboard.
必要な工具と部品
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
