はじめに
The Coin-Cell Battery is a power source for the motherboard while the computer is off. It is used to keep track of the system clock.
必要な工具と部品
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
