メインコンテンツにスキップ
Dell Inspiron 14-7437 Coin Cell Battery Replacement
必要な工具と部品
  1. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: 手順 1、 2の画像 1 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: 手順 1、 2の画像 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 手順 2、 2の画像 1 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 手順 2、 2の画像 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: 手順 3、 2の画像 1 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: 手順 3、 2の画像 2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 手順 4、 1の画像 1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 手順 5、 1の画像 1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Speaker: 手順 6、 1の画像 1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 手順 7、 3の画像 1 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 手順 7、 3の画像 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 手順 7、 3の画像 3
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Coin Cell Battery: 手順 8、 1の画像 1
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 手順 9、 2の画像 1 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 手順 9、 2の画像 2
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Katelyn Remy
メンバー登録日: 03/10/16
449 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 7-8, Catania Spring 2016 UMass Dartmouth, Team 7-8, Catania Spring 2016人のメンバー
UMASSD-CATANIA-S16S7G8
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 12
今までの合計 1,309
