はじめに
A damaged motherboard can cause severe issues with a PC. The Inspiron 14-5447's motherboard is hidden behind several components and a plastic barrier. This guide will show how to remove the remaining components and the barrier, as well as the motherboard itself.
Before beginning this guide, make sure that your computer is OFF, and that the components in the prerequisite replacement guides are removed. The tools needed to remove the motherboard are a Philips head screwdriver, tweezers, and a spudger (or any small prying tool).
必要な工具と部品
Locate the five small slits at the top of the keyboard.
Using a plastic opening tool, carefully pry each slit to loosen the keyboard.
Slide the keyboard towards the screen at an angle for removal.
Locate and unscrew the black (5.70mm) screws on the top left and bottom right of the Hard drive.
Lift up the hard drive from the right side with caution as wires are connected to this unit.
Holding the right side the hard drive and and with the other hand on the black connector (left side). Pull apart from each other carefully.
Locate the heat-sink. This will be a black metal bar at the top of the laptop, which covers the motherboard.
Unscrew the four metallic-colored (2.9mm) screws securing the heat-sink.
Locate and unscrew the top two black (5.70mm) screws, which secure the motherboard to the base of the laptop.
Lift the heatsink, and set aside.
2 の人々がこのガイドを完成させました。
