メインコンテンツにスキップ
Dell Inspiron 14-3452 Screen Replacement
必要な工具と部品
  1. Dell Inspiron 14-3452 Screen Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron 14-3452 Screen Replacement, Battery: 手順 1、 2の画像 2
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Dell Inspiron 14-3452 Screen Replacement, Random Access Memory (RAM): 手順 2、 1の画像 1
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Dell Inspiron 14-3452 Screen Replacement: 手順 3、 1の画像 1
    • Pull the backing away from the laptop.
  4. Dell Inspiron 14-3452 Screen Replacement: 手順 4、 1の画像 1
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  5. Dell Inspiron 14-3452 Screen Replacement: 手順 5、 1の画像 1
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
  6. Dell Inspiron 14-3452 Screen Replacement, Screen: 手順 6、 1の画像 1
    • Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
    • Remove the one Phillips Head 3 mm #0 screw from the computer backing.
  7. Dell Inspiron 14-3452 Screen Replacement: 手順 7、 2の画像 1 Dell Inspiron 14-3452 Screen Replacement: 手順 7、 2の画像 2
    • Remove the white and black antenna cables from the wireless card.
  8. Dell Inspiron 14-3452 Screen Replacement: 手順 8、 1の画像 1
    • Remove the Phillips Head 3 mm #0 screw that is holding the wireless card in place.
  9. Dell Inspiron 14-3452 Screen Replacement: 手順 9、 1の画像 1
    • Slide the wireless card out of the wireless card bay.
  10. Dell Inspiron 14-3452 Screen Replacement: 手順 10、 2の画像 1 Dell Inspiron 14-3452 Screen Replacement: 手順 10、 2の画像 2
    • Using your fingertips remove the speaker cable from the motherboard by pulling the white connector away from the socket.
  11. Dell Inspiron 14-3452 Screen Replacement: 手順 11、 1の画像 1
    • Pry apart the keyboard assembly slowly as the keyboard cable will still be attached to the motherboard.
    • Use the blue Uspudger to pry apart the keyboard assembly from the bottom shell.
  12. Dell Inspiron 14-3452 Screen Replacement: 手順 12、 1の画像 1
    • Disconnect the keyboard cable from the motherboard by lifting the black latch and pulling the cable out of its socket.
  13. Dell Inspiron 14-3452 Screen Replacement: 手順 13、 2の画像 1 Dell Inspiron 14-3452 Screen Replacement: 手順 13、 2の画像 2
    • Disconnect the display cable from the motherboard by pulling the tape back and lifting the connector latch.
    • Pull the display cable away from the motherboard.
  14. Dell Inspiron 14-3452 Screen Replacement: 手順 14、 1の画像 1
    • Remove the power adapter cable from the motherboard by sliding the cable out of its socket.
  15. Dell Inspiron 14-3452 Screen Replacement: 手順 15、 1の画像 1
    • Turn laptop over to access the screen hinge screws.
    • Remove the two Phillips Head 5 mm #0 screws from the two hinges.
  16. Dell Inspiron 14-3452 Screen Replacement: 手順 16、 2の画像 1 Dell Inspiron 14-3452 Screen Replacement: 手順 16、 2の画像 2
    • Using your fingertips, gently pry up the inner edges of the display bezel.
    • Lift the display bezel off the display assembly.
  17. Dell Inspiron 14-3452 Screen Replacement: 手順 17、 3の画像 1 Dell Inspiron 14-3452 Screen Replacement: 手順 17、 3の画像 2 Dell Inspiron 14-3452 Screen Replacement: 手順 17、 3の画像 3
    • After removing the bezel, locate the tab indicated in the pictures.
    • Lift the tab as shown in the pictures.
    • Lift the gold latch securing the display cable to the socket.
    • Pull display cable away from the socket.
終わりに
作成者
3人の作成者と共同で作成されました。
Alec Siegel
メンバー登録日: 01/30/18
598 ポイント
4のガイドは作成済み
チーム
Baylor, Team S2-G2, Johnson Spring 2018 Baylor, Team S2-G2, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S2G2
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 894
