メインコンテンツにスキップ
Dell Inspiron 14 N4050 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron 14 N4050 Display Assembly Replacement, Disconnecting the Display Cable: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the display cable from the connector on the system board.
  2. Dell Inspiron 14 N4050 Display Assembly Replacement, Disconnecting the Mini-Card Antenna Cables: 手順 2、 1の画像 1
    • Disconnect the Mini-Card antenna cables from the connectors on the Mini-Card.
  3. Dell Inspiron 14 N4050 Display Assembly Replacement, Removing the Cables: 手順 3、 1の画像 1
    • Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
  4. Dell Inspiron 14 N4050 Display Assembly Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Remove the two screws that secure the display assembly to the computer base.
  5. Dell Inspiron 14 N4050 Display Assembly Replacement, Removing the Display Assembly: 手順 5、 1の画像 1
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron 14 N4050 Display Assembly Replacement, Placing the Display Assembly: 手順 6、 1の画像 1
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  7. Dell Inspiron 14 N4050 Display Assembly Replacement, Routing the Display Cable: 手順 7、 1の画像 1
    • Route the display cable and Mini-Card antenna cables through the routing guides.
  8. Dell Inspiron 14 N4050 Display Assembly Replacement, Connecting the Display Cable: 手順 8、 1の画像 1
    • Connect the display cable to the connector on the system board.
  9. Dell Inspiron 14 N4050 Display Assembly Replacement, Conencting the Antenna Cables: 手順 9、 2の画像 1 Dell Inspiron 14 N4050 Display Assembly Replacement, Conencting the Antenna Cables: 手順 9、 2の画像 2
    • Connect the Mini-Card antenna cables to the Mini-Card.
ゴール
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,243 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,989のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 705
