はじめに
In this guide, we will be showing you how to remove and replace the Display Assembly.
必要な工具と部品
Make a note of the routing of the Mini-Card antenna cables and the display cables. Remove the cables from the routing guides.
Remove the two screws (one on each side) that secure the display assembly to the computer base.
Make a note of the cable routing and disconnect the display cable and the wireless card antenna cables from the connectors on the Mini-Card.
Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
Route the Mini-Card antenna cables and the display cable through the slot on the computer base.
