はじめに
In this guide, we will be showing you how to remove and replace the Hard-Drive Assembly.
必要な工具と部品
Remove the four screws that secure the hard-drive assembly to the computer base.
Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
Replace the four screws that secure the hard-drive assembly to the computer base.
ある他の人がこのガイドを完成しました。
