メインコンテンツにスキップ
Dell Inspiron 13z 5323 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 13z 5323 Battery Replacement, Battery: 手順 1、 3の画像 1 Dell Inspiron 13z 5323 Battery Replacement, Battery: 手順 1、 3の画像 2 Dell Inspiron 13z 5323 Battery Replacement, Battery: 手順 1、 3の画像 3
    • Remove nine screws from the bottom case.
    • The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
    • Once the captive screw is loosened, remove the small base cover on the bottom of the device.
  2. Dell Inspiron 13z 5323 Battery Replacement: 手順 2、 3の画像 1 Dell Inspiron 13z 5323 Battery Replacement: 手順 2、 3の画像 2 Dell Inspiron 13z 5323 Battery Replacement: 手順 2、 3の画像 3
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
    • Be careful when pushing in the keyboard tabs, as they may break if they if too much pressure is applied to them.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Battery Replacement: 手順 3、 3の画像 1 Dell Inspiron 13z 5323 Battery Replacement: 手順 3、 3の画像 2 Dell Inspiron 13z 5323 Battery Replacement: 手順 3、 3の画像 3
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • Be careful when separating the palm rest from the laptop, because being too aggressive with it can cause the small clips that hold the palm rest in place to break .
  4. Dell Inspiron 13z 5323 Battery Replacement: 手順 4、 3の画像 1 Dell Inspiron 13z 5323 Battery Replacement: 手順 4、 3の画像 2 Dell Inspiron 13z 5323 Battery Replacement: 手順 4、 3の画像 3
    • Remove the screws surrounding the battery and unplug the cable in the top left corner to then remove the battery.
終わりに
作成者
1人の作成者と共同作成されました。
Chase Hussey
メンバー登録日: 03/08/17
201 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G6, Botvin Spring 2017 UMass Dartmouth, Team S5-G6, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S5G6
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 13
今までの合計 851
