はじめに
In this guide, we will show you how to remove and replace the Hard Drive.
必要な工具と部品
Remove the four screws that secure the hard drive assembly to the computer base.
Slide the hard drive assembly to disconnect it from the system board connector.
Pull the black pull-tab and lift the hard drive assembly out of the computer base.
Replace the four screws that secure the hard drive to the hard drive cage.
Slide and connect the hard drive assembly to the system board connector.
Replace the four screws that secure the hard drive assembly to the computer base.
もう少しです!
ゴール
