メインコンテンツにスキップ
Dell Inspiron 1318 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron 1318 Display Assembly Replacement, Removing the Antenna Cables: 手順 1、 1の画像 1
    • Make note of the cable routing and carefully remove the antenna cables from their routing guides. Pull the cables with their connectors through the system board so that they are clear of the computer base.
  2. Dell Inspiron 1318 Display Assembly Replacement, Removing the Screws: 手順 2、 1の画像 1
    • Remove the two M2.5 x 5-mm screws from the computer base.
    • NOTE: Note how the display cable and the camera cable have been routed through their routing guides.
  3. Dell Inspiron 1318 Display Assembly Replacement, Disconnecting the Display Cable: 手順 3、 1の画像 1
    • Pull the display cable tab to disconnect the display cable from the system board connector.
  4. Dell Inspiron 1318 Display Assembly Replacement, Disconnecting the Camera Cable: 手順 4、 1の画像 1
    • Disconnect the camera cable from the system board connector.
  5. Dell Inspiron 1318 Display Assembly Replacement, Dislodging the Cables: 手順 5、 1の画像 1
    • Make note of the cable routing and carefully dislodge the antenna cables and the rest of the cables from their routing guides. Pull the cables away, so that they are clear of the palm rest.
  6. Dell Inspiron 1318 Display Assembly Replacement, Remove the Screws: 手順 6、 1の画像 1
    • Remove the two M2.5 x 5-mm screws from either side of the display assembly.
  7. Dell Inspiron 1318 Display Assembly Replacement, Removing the Display Assembly: 手順 7、 1の画像 1
    • Lift and remove the display assembly from the computer base.
  8. Dell Inspiron 1318 Display Assembly Replacement, Routing the Cables: 手順 8、 1の画像 1
    • Route and connect the display cable to the connector on the system board.
    • Route and connect the camera cable to the connector on the system board.
    • Carefully route the WLAN antenna cables into their routing guides on the palm rest and through the computer base.
  9. Dell Inspiron 1318 Display Assembly Replacement, Replace the Screws: 手順 9、 1の画像 1
    • Replace the two M2.5 x 5-mm screws on each side of the display assembly.
  10. Dell Inspiron 1318 Display Assembly Replacement, Turn the Computer Over: 手順 10、 1の画像 1
    • Turn the computer over and replace the two M2.5 x 5-mm screws on the computer base.
  11. Dell Inspiron 1318 Display Assembly Replacement, Routing the Cables: 手順 11、 1の画像 1
    • Carefully route the WLAN card antenna cables through their routing guides and connect them to the WLAN card.
ゴール
作成者
2人の作成者と共同で作成されました。
Terrence15
メンバー登録日: 12/18/17
79,555 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 205
