メインコンテンツにスキップ
Dell Inspiron 13-7373 Motherboard Replacement
必要な工具と部品
  1. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: 手順 1、 3の画像 1 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: 手順 1、 3の画像 2 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: 手順 1、 3の画像 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Motherboard Replacement, Battery: 手順 2、 1の画像 1
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Motherboard Replacement: 手順 3、 2の画像 1 Dell Inspiron 13-7373 Motherboard Replacement: 手順 3、 2の画像 2
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Motherboard Replacement: 手順 4、 2の画像 1 Dell Inspiron 13-7373 Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Motherboard Replacement, Fan: 手順 5、 1の画像 1
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Motherboard Replacement: 手順 6、 1の画像 1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Motherboard Replacement, Network Card: 手順 7、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Motherboard Replacement, Daughterboard: 手順 8、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Motherboard Replacement: 手順 9、 1の画像 1
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Motherboard Replacement, Motherboard: 手順 10、 1の画像 1
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Motherboard Replacement: 手順 11、 3の画像 1 Dell Inspiron 13-7373 Motherboard Replacement: 手順 11、 3の画像 2 Dell Inspiron 13-7373 Motherboard Replacement: 手順 11、 3の画像 3
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Motherboard Replacement: 手順 12、 1の画像 1
    • Gently lift up on the motherboard to remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
John Egan
メンバー登録日: 10/25/19
449 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019人のメンバー
UMASSD-O'CONNELL-F19S1G4
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 1,232
