メインコンテンツにスキップ
Dell Inspiron 13-7373 Fan Replacement
必要な工具と部品
  1. Dell Inspiron 13-7373 Fan Replacement, Back Cover: 手順 1、 3の画像 1 Dell Inspiron 13-7373 Fan Replacement, Back Cover: 手順 1、 3の画像 2 Dell Inspiron 13-7373 Fan Replacement, Back Cover: 手順 1、 3の画像 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Fan Replacement, Fan: 手順 2、 1の画像 1
    • Remove the two screws holding the cover for the fan.
  3. Dell Inspiron 13-7373 Fan Replacement: 手順 3、 1の画像 1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
終わりに
To reassemble your device with the new fan, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Kameron Jusseaume
メンバー登録日: 10/25/19
465 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019人のメンバー
UMASSD-O'CONNELL-F19S1G4
3 メンバー
5のガイドは作成済み
2 件のコメント
This was most helpful. We have a Dell 7373 model and the fan is quite noisy. We are going to disassemble and clean/replace it. Your tutorial explained it all. Thank you.
martyfukui - 返信
these 7373 seem to have a fan issue- I do IT for a business that has like 10 of them and at least 2 developed the same issue after a couple years- ordered new fans off of Amazon (tons of them and all look same except some have a flange on the bottom?) and no way to differentiate quality- both redeveloped the problem soon after installing fan- both were clean inside w no obvious issue- guessing the thin case has possibly bent down a tad and puts pressure on it- might take apart and see if I can bend part of case out a bit?) geez dell.
Garry Masters - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 1,174
