メインコンテンツにスキップ
Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement
必要な工具と部品
  1. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Battery: 手順 1、 1の画像 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 2、 1の画像 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 3、 3の画像 1 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 3、 3の画像 2 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 3、 3の画像 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 4、 3の画像 1 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 4、 3の画像 2 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 4、 3の画像 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Hard Drive: 手順 5、 1の画像 1
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  6. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 6、 2の画像 1 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 6、 2の画像 2
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
  7. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, WLAN Adaptor: 手順 7、 1の画像 1
    • Unhook both of the wires attached to the WLAN adaptor.
  8. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 8、 1の画像 1
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  9. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 9、 1の画像 1
    • Gently remove the WLAN adaptor.
  10. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, USB/SD Card Reader IO Circuit Board: 手順 10、 1の画像 1
    • Using the plastic opening tool, unhook the black cable as shown.
  11. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 11、 1の画像 1
    • Gently pull to unplug the speaker cable.
  12. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 12、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the 3.9mm Phillips screw as shown.
  13. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 手順 13、 1の画像 1
    • Gently raise the USB/SD Card Reader IO Circuit Board and pull the part free from the device.
終わりに
作成者
1人の作成者と共同作成されました。
Bo Yi Lim
メンバー登録日: 04/02/19
205 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S3-G4, Harley Spring 2019 IUPUI, Team S3-G4, Harley Spring 2019人のメンバー
IUPUI-HARLEY-S19S3G4
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 367
