メインコンテンツにスキップ
Dell Inspiron 13-7359 Speaker Replacement
必要な工具と部品
  1. Dell Inspiron 13-7359 Speaker Replacement, Battery: 手順 1、 1の画像 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Speaker Replacement: 手順 2、 1の画像 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Speaker Replacement: 手順 3、 3の画像 1 Dell Inspiron 13-7359 Speaker Replacement: 手順 3、 3の画像 2 Dell Inspiron 13-7359 Speaker Replacement: 手順 3、 3の画像 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Speaker Replacement: 手順 4、 3の画像 1 Dell Inspiron 13-7359 Speaker Replacement: 手順 4、 3の画像 2 Dell Inspiron 13-7359 Speaker Replacement: 手順 4、 3の画像 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 Speaker Replacement, Speaker: 手順 5、 2の画像 1 Dell Inspiron 13-7359 Speaker Replacement, Speaker: 手順 5、 2の画像 2
    • Following the removal of the Battery, remove the left speaker.
    • As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
  6. Dell Inspiron 13-7359 Speaker Replacement: 手順 6、 2の画像 1 Dell Inspiron 13-7359 Speaker Replacement: 手順 6、 2の画像 2
    • Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
  7. Dell Inspiron 13-7359 Speaker Replacement: 手順 7、 2の画像 1 Dell Inspiron 13-7359 Speaker Replacement: 手順 7、 2の画像 2
    • Use the plastic spudger to safely and easily detach the right speaker from the device.
    • Lift the right speaker out to complete the removal.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Katie Ragsdale
メンバー登録日: 01/30/18
192 ポイント
1ガイドが承認済み
チーム
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S1G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 384
