メインコンテンツにスキップ
Dell Inspiron 13-7359 Screen Replacement
必要な工具と部品
  1. Dell Inspiron 13-7359 Screen Replacement, Battery: 手順 1、 1の画像 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Screen Replacement: 手順 2、 1の画像 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Screen Replacement: 手順 3、 3の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 3、 3の画像 2 Dell Inspiron 13-7359 Screen Replacement: 手順 3、 3の画像 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Screen Replacement: 手順 4、 3の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 4、 3の画像 2 Dell Inspiron 13-7359 Screen Replacement: 手順 4、 3の画像 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 Screen Replacement, Hard Drive: 手順 5、 1の画像 1
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  6. Dell Inspiron 13-7359 Screen Replacement: 手順 6、 2の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 6、 2の画像 2
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
  7. Dell Inspiron 13-7359 Screen Replacement, Cooling Fan: 手順 7、 2の画像 1 Dell Inspiron 13-7359 Screen Replacement, Cooling Fan: 手順 7、 2の画像 2
    • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
  8. Dell Inspiron 13-7359 Screen Replacement: 手順 8、 1の画像 1
    • Hold the cooling fan with one hand.
    • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
    • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
  9. Dell Inspiron 13-7359 Screen Replacement, Screen: 手順 9、 1の画像 1
    • Make sure that the Battery, Hard Drive, and Cooling Fan are safely removed.
  10. Dell Inspiron 13-7359 Screen Replacement: 手順 10、 2の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 10、 2の画像 2
    • Unplug antenna cables located at the top left corner.
    • Unplug daughter board located to the bottom left of the cooling fan.
  11. Dell Inspiron 13-7359 Screen Replacement: 手順 11、 2の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 11、 2の画像 2
    • Find the heat sink (copper colored metal).
    • Use Phillips 0 screwdriver to loosen the 3 of the 3mm Phillips head screws from the heat sink.
    • Remove the heat sink
  12. Dell Inspiron 13-7359 Screen Replacement: 手順 12、 3の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 12、 3の画像 2 Dell Inspiron 13-7359 Screen Replacement: 手順 12、 3の画像 3
    • Use Phillips 0 screwdriver to unscrew the 2 of the 3mm screws holding the LCD cable bracket in place.
    • Remove the LCD cable bracket.
    • Unplug LCD and touchscreen cables.
  13. Dell Inspiron 13-7359 Screen Replacement: 手順 13、 3の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 13、 3の画像 2 Dell Inspiron 13-7359 Screen Replacement: 手順 13、 3の画像 3
    • Use Phillips 0 screwdriver to unscrew and remove the 3 of the 7mm screws from the LCD display.
    • Open the laptop so that the screen and keyboard are face down on the desk.
    • Carefully disconnect the LCD display by lifting the screen upward and away from the bottom half of the laptop.
  14. Dell Inspiron 13-7359 Screen Replacement: 手順 14、 2の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 14、 2の画像 2
    • Using a plastic spudger carefully separate the casing of the screen.
  15. Dell Inspiron 13-7359 Screen Replacement: 手順 15、 3の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 15、 3の画像 2 Dell Inspiron 13-7359 Screen Replacement: 手順 15、 3の画像 3
    • Use the plastic spudger to disconnect the mini circuit board from the casing.
    • Disconnect the small wires connecting the screen to the casing.
  16. Dell Inspiron 13-7359 Screen Replacement: 手順 16、 2の画像 1 Dell Inspiron 13-7359 Screen Replacement: 手順 16、 2の画像 2
    • Remove the loose wiring from the perimeter of the screen.
    • Gently separate the LCD screen from the laptop casing.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Austin Navarro
メンバー登録日: 01/30/18
255 ポイント
1ガイドが承認済み
チーム
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S1G6
3 メンバー
5のガイドは作成済み
コメント 1 件
Hi, I was wondering if there's any possibility of cross compatibility between i7378 and i7359 from dell? My computer is the i7359 but I haven't been able to find a reasonably priced replacement display. Thank you very much! Also, I found this alternate guide suggesting that the screen can be replaced slightly more easily than the manual and this guide suggests, is this process feasible? https://www.insidemylaptop.com/replacing...
Ankita C - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 27
今までの合計 5,420
