メインコンテンツにスキップ
Dell Inspiron 13-7353 Screen Replacement
必要な工具と部品
  1. Dell Inspiron 13-7353 Screen Replacement, Flip the Computer: 手順 1、 1の画像 1
    • WARNING: Please read the safety information shipped with your computer and follow recommended steps before working inside your computer. When finished working inside your computer, follow the instructions included in the safety information.
    • Close the computer display and turn the computer over so that the base of the computer is facing up.
  2. Dell Inspiron 13-7353 Screen Replacement, Secure the Base: 手順 2、 1の画像 1
    • Remove the ten screws that secure the base cover to the base of the computer.
  3. Dell Inspiron 13-7353 Screen Replacement, Pry the Base cover: 手順 3、 1の画像 1
    • Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
  4. Dell Inspiron 13-7353 Screen Replacement, RAM: 手順 4、 2の画像 1 Dell Inspiron 13-7353 Screen Replacement, RAM: 手順 4、 2の画像 2
    • Before opening your device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Dell Inspiron 13-7353 Screen Replacement: 手順 5、 2の画像 1 Dell Inspiron 13-7353 Screen Replacement: 手順 5、 2の画像 2
    • Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
    • Remove the battery.
  6. Dell Inspiron 13-7353 Screen Replacement: 手順 6、 3の画像 1 Dell Inspiron 13-7353 Screen Replacement: 手順 6、 3の画像 2 Dell Inspiron 13-7353 Screen Replacement: 手順 6、 3の画像 3
    • Pry open the two clips.
    • Gently lift the RAM stick and pull it out of the motherboard.
  7. Dell Inspiron 13-7353 Screen Replacement, Fan: 手順 7、 3の画像 1 Dell Inspiron 13-7353 Screen Replacement, Fan: 手順 7、 3の画像 2 Dell Inspiron 13-7353 Screen Replacement, Fan: 手順 7、 3の画像 3
    • Unplug the daughterboard cable in two places, then remove the daughterboard.
    • Unplug the fan cable.
  8. Dell Inspiron 13-7353 Screen Replacement: 手順 8、 2の画像 1 Dell Inspiron 13-7353 Screen Replacement: 手順 8、 2の画像 2
    • Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
    • Remove the cooling fan from the laptop.
  9. Dell Inspiron 13-7353 Screen Replacement, Heat Sink: 手順 9、 3の画像 1 Dell Inspiron 13-7353 Screen Replacement, Heat Sink: 手順 9、 3の画像 2 Dell Inspiron 13-7353 Screen Replacement, Heat Sink: 手順 9、 3の画像 3
    • Remove three 2mm screws from the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  10. Dell Inspiron 13-7353 Screen Replacement, Screen: 手順 10、 3の画像 1 Dell Inspiron 13-7353 Screen Replacement, Screen: 手順 10、 3の画像 2 Dell Inspiron 13-7353 Screen Replacement, Screen: 手順 10、 3の画像 3
    • Remove the screws from the LCD cable bracket.
    • Remove the LCD cable bracket.
  11. Dell Inspiron 13-7353 Screen Replacement: 手順 11、 3の画像 1 Dell Inspiron 13-7353 Screen Replacement: 手順 11、 3の画像 2 Dell Inspiron 13-7353 Screen Replacement: 手順 11、 3の画像 3
    • Unplug the LCD cable.
    • Unplug the touchscreen cable.
  12. Dell Inspiron 13-7353 Screen Replacement: 手順 12、 3の画像 1 Dell Inspiron 13-7353 Screen Replacement: 手順 12、 3の画像 2 Dell Inspiron 13-7353 Screen Replacement: 手順 12、 3の画像 3
    • Unscrew 2 M2.5 7mm screws, using the Phillips 1 screwdriver, on the right screen hinge.
    • Unscrew 1 M2.5 7mm screw, using the Phillips 1 screwdriver, on the left screen hinge.
  13. Dell Inspiron 13-7353 Screen Replacement: 手順 13、 2の画像 1 Dell Inspiron 13-7353 Screen Replacement: 手順 13、 2の画像 2
    • Carefully undo the tape
    • Unplug the two black and white wire leads
  14. Dell Inspiron 13-7353 Screen Replacement: 手順 14、 3の画像 1 Dell Inspiron 13-7353 Screen Replacement: 手順 14、 3の画像 2 Dell Inspiron 13-7353 Screen Replacement: 手順 14、 3の画像 3
    • Carefully remove the tape that is attached to the screen by prying it off with your fingers.
    • Remove the tape outlined in red.
    • Adjust the screen so that the laptop is open flat against the surface.
    • Remove the LCD display screen by pulling it gently away from the back.
終わりに
作成者
4人の作成者と共同で作成されました。
Stephany Marin Restrepo
メンバー登録日: 03/19/18
613 ポイント
5のガイドは作成済み
チーム
University of Memphis, Team S2-G2, Kim Spring 2018 University of Memphis, Team S2-G2, Kim Spring 2018人のメンバー
UM-KIM-S18S2G2
3 メンバー
5のガイドは作成済み
2 件のコメント
Wow. Thank you so much. I will do this when I get my replacement screen.
Chris Gallego - 返信
Finally tried this and noticed you left out the most difficult part which is the part of putting on the actually replacing the screen. This is only for removal of the screen. And the instructions are definitely not the same backwards. You left out the part with the cable/wires closing with the hinges being the most difficult part. I actually forced the cable too much stripped the cable that goes around the new screen. Have to order new cable now ugh
Chris Gallego -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 2,215
