メインコンテンツにスキップ
Dell Inspiron 13-7353 Heat Sink Replacement
必要な工具と部品
  1. Dell Inspiron 13-7353 Heat Sink Replacement, Flip the Computer: 手順 1、 1の画像 1
    • WARNING: Please read the safety information shipped with your computer and follow recommended steps before working inside your computer. When finished working inside your computer, follow the instructions included in the safety information.
    • Close the computer display and turn the computer over so that the base of the computer is facing up.
  2. Dell Inspiron 13-7353 Heat Sink Replacement, Secure the Base: 手順 2、 1の画像 1
    • Remove the ten screws that secure the base cover to the base of the computer.
  3. Dell Inspiron 13-7353 Heat Sink Replacement, Pry the Base cover: 手順 3、 1の画像 1
    • Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
  4. Dell Inspiron 13-7353 Heat Sink Replacement, RAM: 手順 4、 2の画像 1 Dell Inspiron 13-7353 Heat Sink Replacement, RAM: 手順 4、 2の画像 2
    • Before opening your device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Dell Inspiron 13-7353 Heat Sink Replacement: 手順 5、 2の画像 1 Dell Inspiron 13-7353 Heat Sink Replacement: 手順 5、 2の画像 2
    • Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
    • Remove the battery.
  6. Dell Inspiron 13-7353 Heat Sink Replacement: 手順 6、 3の画像 1 Dell Inspiron 13-7353 Heat Sink Replacement: 手順 6、 3の画像 2 Dell Inspiron 13-7353 Heat Sink Replacement: 手順 6、 3の画像 3
    • Pry open the two clips.
    • Gently lift the RAM stick and pull it out of the motherboard.
  7. Dell Inspiron 13-7353 Heat Sink Replacement, Fan: 手順 7、 3の画像 1 Dell Inspiron 13-7353 Heat Sink Replacement, Fan: 手順 7、 3の画像 2 Dell Inspiron 13-7353 Heat Sink Replacement, Fan: 手順 7、 3の画像 3
    • Unplug the daughterboard cable in two places, then remove the daughterboard.
    • Unplug the fan cable.
  8. Dell Inspiron 13-7353 Heat Sink Replacement: 手順 8、 2の画像 1 Dell Inspiron 13-7353 Heat Sink Replacement: 手順 8、 2の画像 2
    • Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
    • Remove the cooling fan from the laptop.
  9. Dell Inspiron 13-7353 Heat Sink Replacement, Heat Sink: 手順 9、 3の画像 1 Dell Inspiron 13-7353 Heat Sink Replacement, Heat Sink: 手順 9、 3の画像 2 Dell Inspiron 13-7353 Heat Sink Replacement, Heat Sink: 手順 9、 3の画像 3
    • Remove three 2mm screws from the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Stephany Marin Restrepo
メンバー登録日: 03/19/18
613 ポイント
5のガイドは作成済み
チーム
University of Memphis, Team S2-G2, Kim Spring 2018 University of Memphis, Team S2-G2, Kim Spring 2018人のメンバー
UM-KIM-S18S2G2
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 278
