はじめに
The Hard Drive is your main storage place on your laptop. This is responsible for holding everything on your laptop from simple documents to your installed operating system. Also adding a bigger hard drive might speed up your laptop if your current one is full or corrupt
必要な工具と部品
Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
Use the plastic opening tool to pry up and loosen the back panel.
Remove the back panel.
Locate the Hard Drive.
Remove the two 3mm screws from Hard Drive with the Phillips #0 head.
Disconnect the wire attached to the system board by lifting up the tape.
Remove the tape tab from the Hard Drive by lifting the tape up and off of the Hard Drive unit.
5 の人々がこのガイドを完成させました。
