メインコンテンツにスキップ
Dell Inspiron 13-5378 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron 13-5378 Display Assembly Replacement, Peeling the Tape: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Peel off the pieces of tape that secure the display cable and touch-screen board-cable to the system board.
  2. Dell Inspiron 13-5378 Display Assembly Replacement, Open the Latches: 手順 2、 1の画像 1
    • Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
  3. Dell Inspiron 13-5378 Display Assembly Replacement, Open the Display: 手順 3、 1の画像 1
    • Turn the computer over and open the display as far as possible.
  4. Dell Inspiron 13-5378 Display Assembly Replacement, Placing the Computer: 手順 4、 1の画像 1
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
    • Place the computer face down on a flat surface.
  5. Dell Inspiron 13-5378 Display Assembly Replacement, Remove the Screws: 手順 5、 1の画像 1
    • Remove the screws that secure the display assembly to the palm-rest assembly.
  6. Dell Inspiron 13-5378 Display Assembly Replacement, Lifting the Display Assembly: 手順 6、 1の画像 1
    • Lift the display assembly off the palm-rest assembly.
  7. Dell Inspiron 13-5378 Display Assembly Replacement, Placing the Display Assembly: 手順 7、 1の画像 1
    • Place the NEW display assembly face down on the palm-rest assembly.
  8. Dell Inspiron 13-5378 Display Assembly Replacement, Align the Screw Holes: 手順 8、 1の画像 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
    • Close the display and turn the computer over.
  9. Dell Inspiron 13-5378 Display Assembly Replacement, Sliding the Display Cable: 手順 10、 2の画像 1 Dell Inspiron 13-5378 Display Assembly Replacement, Sliding the Display Cable: 手順 10、 2の画像 2
    • Slide the display cable and the touch-screen board-cable into their respective connectors on the system board and close the latches to secure the cables.
  10. Dell Inspiron 13-5378 Display Assembly Replacement, Adhering the Pieces: 手順 11、 1の画像 1
    • Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
終わりに
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,309 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,984のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 26
今までの合計 3,331
