メインコンテンツにスキップ
はじめに
In this guide, we will show you how to remove and replace the Battery.
パーツ
パーツは指定されていません。
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer. Disconnect the battery cable from the system board.
  2. Remove the screws that secure the battery to the palm-rest assembly.
    • Remove the screws that secure the battery to the palm-rest assembly.
  3. Lift the battery off the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
  4. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    • Press and hold the power button for five seconds to ground the system board.
  5. Align the screw holes on the NEW battery with the screw holes on the palm-rest assembly.
    • Align the screw holes on the NEW battery with the screw holes on the palm-rest assembly.
  6. Replace the screws that secure the battery to the palm-rest assembly.
    • Replace the screws that secure the battery to the palm-rest assembly.
  7. Connect the battery cable to the system board.
    • Connect the battery cable to the system board.
まとめ
ある他の人がこのガイドを完成しました。
Terrence15
メンバー登録日: 2017年12月18日
70,858 ポイント
442のガイドは作成済み
チーム
Informative Technologies Inc. Informative Technologies Inc.人のメンバー
Community
15 メンバー
930のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 6
過去 7 日: 32
過去 30 日: 94
今までの合計 931
