メインコンテンツにスキップ
Dell Inspiron 11z-1121 Fan Replacement
必要な工具と部品
  1. Dell Inspiron 11z-1121 Fan Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron 11z-1121 Fan Replacement, Battery: 手順 1、 2の画像 2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Fan Replacement, Keyboard: 手順 2、 2の画像 1 Dell Inspiron 11z-1121 Fan Replacement, Keyboard: 手順 2、 2の画像 2
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Fan Replacement: 手順 3、 2の画像 1 Dell Inspiron 11z-1121 Fan Replacement: 手順 3、 2の画像 2
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Fan Replacement: 手順 4、 2の画像 1 Dell Inspiron 11z-1121 Fan Replacement: 手順 4、 2の画像 2
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 11z-1121 Fan Replacement, Fan: 手順 5、 2の画像 1 Dell Inspiron 11z-1121 Fan Replacement, Fan: 手順 5、 2の画像 2
    • Start by prying the outer casing of the laptop using the plastic opening tool. Start from the bottom and work your way around the edges.
  6. Dell Inspiron 11z-1121 Fan Replacement: 手順 6、 2の画像 1 Dell Inspiron 11z-1121 Fan Replacement: 手順 6、 2の画像 2
    • Remove the outer casing to expose the motherboard.
    • Remove five .75 mm screws using a PH1 screwdriver.
    • Make sure to keep track of your screws.
  7. Dell Inspiron 11z-1121 Fan Replacement: 手順 7、 1の画像 1
    • Remove wireless wide area network (WWAN) card by sliding it out of position.
    • Make sure the wires attached to the WWAN card are not detached when doing this step.
  8. Dell Inspiron 11z-1121 Fan Replacement: 手順 8、 2の画像 1 Dell Inspiron 11z-1121 Fan Replacement: 手順 8、 2の画像 2
    • Unscrew the two 0.9 mm screws that are holding down the screen.
    • Lift the screen up and towards yourself to detach the screen from the laptop.
  9. Dell Inspiron 11z-1121 Fan Replacement: 手順 9、 1の画像 1
    • Lay the screen down and pry the left corner of the plastic casing that is located behind the screen.
  10. Dell Inspiron 11z-1121 Fan Replacement: 手順 10、 1の画像 1
    • While holding screen, remove the motherboard by wiggling it around and pulling outwards.
    • In this step you are trying to pull the motherboard out from the VGA socket it is attached to in the back left corner of the laptop.
  11. Dell Inspiron 11z-1121 Fan Replacement: 手順 11、 2の画像 1 Dell Inspiron 11z-1121 Fan Replacement: 手順 11、 2の画像 2
    • Unscrew the two black 0.5 mm screws holding the fan in place.
    • Remove the fan by gently lifting the component upwards.
終わりに
作成者
2人の作成者と共同で作成されました。
Cassidy Chen
メンバー登録日: 10/04/16
289 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-5, Nance Fall 2016 USF Tampa, Team 1-5, Nance Fall 2016人のメンバー
USFT-NANCE-F16S1G5
4 メンバー
5のガイドは作成済み
コメント 1 件
I see there are a few more screws on the bottom. Can't we just unscrew those and take off the bottom panel?
bluejedi - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 1,008
