メインコンテンツにスキップ
Dell Inspiron 11z-1121 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Mini-Card Cables: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Dell Inspiron 11z-1121 Display Assembly Replacement, Dislodge the Cables: 手順 2、 1の画像 1
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Display Cable: 手順 3、 1の画像 1
    • Disconnect the display cable from the system board connector.
  4. Dell Inspiron 11z-1121 Display Assembly Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 11z-1121 Display Assembly Replacement, Lifting and Removing the Display Assembly: 手順 5、 1の画像 1
    • Lift and remove the display assembly off the computer base.
  6. Dell Inspiron 11z-1121 Display Assembly Replacement, Replace the Screws: 手順 6、 1の画像 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Display Cable: 手順 7、 1の画像 1
    • Connect the display cable to the system board connector.
  8. Dell Inspiron 11z-1121 Display Assembly Replacement, Routing the Cables: 手順 8、 1の画像 1
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  9. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Cables: 手順 9、 1の画像 1
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
終わりに
作成者
2人の作成者と共同で作成されました。
Terrence15
メンバー登録日: 12/18/17
79,555 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 296
