メインコンテンツにスキップ
Dell Inspiron 11z 1110 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron 11z 1110 Hard Drive Replacement, Remove the Screws: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Remove the three screws that secure the hard drive assembly to the computer base.
  2. Dell Inspiron 11z 1110 Hard Drive Replacement, Pulling the Pull-Tab: 手順 2、 1の画像 1
    • Pull the pull-tab on the hard drive bracket towards the right to disconnect the hard drive assembly from the interposer.
  3. Dell Inspiron 11z 1110 Hard Drive Replacement, Lifting the Hard Drove Assembly: 手順 3、 1の画像 1
    • Pull the pull-tab on the hard drive bracket to lift the hard drive assembly at an angle and out of the hard drive compartment as shown in the illustration.
  4. Dell Inspiron 11z 1110 Hard Drive Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Remove the four screws that secure the hard drive bracket to the hard drive and remove the hard drive bracket.
  5. Dell Inspiron 11z 1110 Hard Drive Replacement, Replacing the Bracket: 手順 5、 1の画像 1
    • Replace the hard drive bracket and the four screws that secure the NEW hard drive bracket to the hard drive.
  6. Dell Inspiron 11z 1110 Hard Drive Replacement, Placing the Hard Drive Assembly: 手順 6、 1の画像 1
    • Place the hard drive assembly in the hard drive compartment.
  7. Dell Inspiron 11z 1110 Hard Drive Replacement, Connecting the Assembly: 手順 7、 1の画像 1
    • Push the hard drive assembly towards the left until it is fully connected to the interposer.
  8. Dell Inspiron 11z 1110 Hard Drive Replacement, Replace the Screws: 手順 8、 1の画像 1
    • Replace the three screws that secure the hard drive assembly to the computer base.
終わりに
To reassemble your computer, follow these instructions in reverse order.
作成者
3人の作成者と共同で作成されました。
Terrence15
メンバー登録日: 12/18/17
79,555 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 1,031
