メインコンテンツにスキップ
Dell Inspiron 11-3180 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 11-3180 Battery Replacement, Bottom Case: 手順 1、 1の画像 1
    • Flip the Chromebook to have the bottom facing you.
    • Make a note of all of the screws present. You may need to uncover some of them hidden beneath plastic tabs. The location of each screw is marked in the accompanying image.
  2. Dell Inspiron 11-3180 Battery Replacement: 手順 2、 1の画像 1
    • Remove all nine of the 6 mm screws on the bottom with a size #00 Phillips screwdriver.
    • If needed, use a toothpick or the tip of your screwdriver to uncover the plastic that's hiding them.
  3. Dell Inspiron 11-3180 Battery Replacement: 手順 3、 1の画像 1
    • Flip the Chromebook upright and open it.
  4. Dell Inspiron 11-3180 Battery Replacement: 手順 4、 1の画像 1
    • Using the iFixit plastic opening tool, wedge it into the seam of the bottom plate. This will create a small gap between the sections that you can gently pry open. Work your way around to each side of the device until the bottom pops free.
    • Caution: DO NOT attempt to fully remove the bottom plate yet, as there are still connected wires. Doing so may result in damage to your device.
  5. Dell Inspiron 11-3180 Battery Replacement: 手順 5、 1の画像 1
    • Once you have pried enough space between the Chromebook and the bottom plate, flip it back over so the bottom plate is facing you and gently pull it up with your hands.
  6. Dell Inspiron 11-3180 Battery Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    購入する
    • Before you completely pull off the back, you must disconnect the MB cord.
    • Using blunt-nosed tweezers, carefully flip the black bar that keeps the MB cord latched in as circled in the image.
    • Once open, grab the flat cord with your tweezers and pull horizontally until it comes free. Your bottom plate is now fully removed.
  7. Dell Inspiron 11-3180 Battery Replacement: 手順 7、 1の画像 1
    • Finally, pull off the bottom plate carefully and set it to the side to continue with your needed repairs or replacements.
  8. Dell Inspiron 11-3180 Battery Replacement, Battery: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • Locate the battery on the lower half of the open laptop.
    • Using blunt-nosed tweezers, carefully disconnect the battery cable from the service board by pulling at the small plastic tabs on either side.
  9. Dell Inspiron 11-3180 Battery Replacement: 手順 9、 2の画像 1 Dell Inspiron 11-3180 Battery Replacement: 手順 9、 2の画像 2
    • Use a #00 Phillips screwdriver to remove the six 4 mm screws.
    • Also remove the one 6 mm screw.
    • Not all screws are pictured, but the locations are circled.
    • There should no longer be any screws holding down the battery.
  10. Dell Inspiron 11-3180 Battery Replacement: 手順 10、 1の画像 1
    • Carefully remove the battery with hands.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Ivy Taylor
メンバー登録日: 10/02/23
653 ポイント
5のガイドは作成済み
チーム
Linn Benton Community College, Team 1-1, Karnes Fall 2023 Linn Benton Community College, Team 1-1, Karnes Fall 2023人のメンバー
LBCC-KARNES-F23S1G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 23
今までの合計 194
