はじめに
This guide will show you how to replace the memory module of the Dell Inspiron 11-3168. Before starting, make sure both the laptop AC adapter and battery are disconnected prior to replacing any part or component.
Note: This guide does not apply to Celeron eMMC systems. These have the memory soldered to the board and require a motherboard replacement.
必要な工具と部品
Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
Press down on the two latches on either side of the memory module.
Lift and remove the memory module.
ある他の人がこのガイドを完成しました。
