メインコンテンツにスキップ
Dell Inspiron 11-3164 Motherboard Replacement
必要な工具と部品
  1. Dell Inspiron 11-3164 Motherboard Replacement, Motherboard: 手順 1、 2の画像 1 Dell Inspiron 11-3164 Motherboard Replacement, Motherboard: 手順 1、 2の画像 2
    • Start by placing the laptop upside down to expose the first set of screws on the bottom of the laptop. Use your J1 Phillips head screwdriver bit to unscrew the 8 size 60 mm screws.
    • Remove the plastic cover to unveil the final screw holding the front and back frame together.
    • Remove this last screw of size 60mm with the J1 phillips head bit found in the approved iFixit toolkit.
  2. Dell Inspiron 11-3164 Motherboard Replacement: 手順 2、 2の画像 1 Dell Inspiron 11-3164 Motherboard Replacement: 手順 2、 2の画像 2
    • Open the latches and disconnect the touch-pad cable and keyboard cable from the system board.
  3. Dell Inspiron 11-3164 Motherboard Replacement: 手順 3、 2の画像 1 Dell Inspiron 11-3164 Motherboard Replacement: 手順 3、 2の画像 2
    • Disconnect the battery cable from the system board.
    • Remove the screws that secure the battery to the palm rest and keyboard assembly by using the PH1 screw driver to unscrew the three size 40 mm battery screws.
    • There is no way that motherboard can be removed with battery pack still attached to the laptop.
  4. Dell Inspiron 11-3164 Motherboard Replacement: 手順 4、 1の画像 1
    • Open the latch and disconnect the I/O-board cable from system board.
  5. Dell Inspiron 11-3164 Motherboard Replacement: 手順 5、 2の画像 1 Dell Inspiron 11-3164 Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the 2mm screw that secures the motherboard and keyboard assembly.
  6. Dell Inspiron 11-3164 Motherboard Replacement: 手順 6、 2の画像 1 Dell Inspiron 11-3164 Motherboard Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • Disconnect the coin-cell battery cable from the system board.
    • To remove the cable, use a small pliers or Angled Precision Tweezers on the left and right ledges on the adapter.
    • Do not pull by the cord.
  7. Dell Inspiron 11-3164 Motherboard Replacement: 手順 7、 1の画像 1
    • Removing the Wireless WLAN Card
    • Remove the M2 x 3mm bracket screw.
    • Remove the metal bracket.
    • With tweezers, detach the white and black antenna cables connected to the Wireless WLAN Card.
    • Remove the Wireless WLAN Card by slide the assembly out of motherboard wireless socket.
  8. Dell Inspiron 11-3164 Motherboard Replacement: 手順 8、 1の画像 1
    • Disconnect the speaker cable from the system board.
  9. Dell Inspiron 11-3164 Motherboard Replacement: 手順 9、 2の画像 1 Dell Inspiron 11-3164 Motherboard Replacement: 手順 9、 2の画像 2
    • Remove the M2xL3 screw on display-cable guard to the system board.
    • Detach the cable beneath.
  10. Dell Inspiron 11-3164 Motherboard Replacement: 手順 10、 1の画像 1
    • Disconnect the power-adapter port cable from the system board.
    • Use angle precision tweezers to put on the ledge alongside the adapter away from the motherboard socket.
    • Warning: to avoid damaging the cord, do not pull by the cable.
  11. Dell Inspiron 11-3164 Motherboard Replacement: 手順 11、 2の画像 1 Dell Inspiron 11-3164 Motherboard Replacement: 手順 11、 2の画像 2
    • Lift the mother board off the palm rest and keyboard assembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Watis Ekthuvapranee
メンバー登録日: 02/14/18
277 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S6G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 443
