はじめに
This guide will show you how to replace the USB Ports on your Dell Inspiron.
必要な工具と部品
After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
Remove the two white power connectors on the bottom right of the motherboard by gently pulling on the tabs backward.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
