メインコンテンツにスキップ
Dell Inspiron 11-3152 Cooling Fan Replacement
必要な工具と部品
  1. Dell Inspiron 11-3152 Cooling Fan Replacement, Back Panel: 手順 1、 2の画像 1 Dell Inspiron 11-3152 Cooling Fan Replacement, Back Panel: 手順 1、 2の画像 2
    • Flip the computer over.
  2. Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 2、 2の画像 1 Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 2、 2の画像 2
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
  3. Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 3、 1の画像 1
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
  4. Dell Inspiron 11-3152 Cooling Fan Replacement, Battery: 手順 4、 1の画像 1
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
  5. Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 5、 2の画像 1 Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 5、 2の画像 2
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
  6. Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 6、 1の画像 1
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
  7. Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 7、 1の画像 1
    • Remove the battery from the computer system by gently lifting it from the side.
  8. Dell Inspiron 11-3152 Cooling Fan Replacement, Cooling Fan: 手順 8、 1の画像 1
    • Locate the cooling fan.
    • The cooling fan is the curved metal piece in the top center of the laptop, opposite the battery.
  9. Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 9、 1の画像 1
    • Using your fingernail, unplug the white power cable connector to the right of the cooling fan by pushing it away from the port.
  10. Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 10、 1の画像 1
    • Remove the four 3mm screws using a Phillips #0 head.
  11. Dell Inspiron 11-3152 Cooling Fan Replacement: 手順 11、 1の画像 1
    • Gently remove the fan.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Hannah Benedict
メンバー登録日: 03/10/16
182 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 4-6, Catania Spring 2016 UMass Dartmouth, Team 4-6, Catania Spring 2016人のメンバー
UMASSD-CATANIA-S16S4G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 16
今までの合計 285
