はじめに
In this guide, you will be replacing the battery to your Dell Inspiron. When finished, you should understand how to dissemble the back panel and remove the battery.
必要な工具と部品
After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
