メインコンテンツにスキップ
Dell Inspiron 10z 1120 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron 10z 1120 Hard Drive Replacement, Remove the Screws: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 10z 1120 Hard Drive Replacement, Sliding the Hard Drive: 手順 2、 1の画像 1
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  3. Dell Inspiron 10z 1120 Hard Drive Replacement, Lifting the Hard-drive: 手順 3、 1の画像 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 10z 1120 Hard Drive Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 10z 1120 Hard Drive Replacement, Lifting the Hard-Drive: 手順 5、 1の画像 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 10z 1120 Hard Drive Replacement, Placing the Hard Drive: 手順 6、 2の画像 1 Dell Inspiron 10z 1120 Hard Drive Replacement, Placing the Hard Drive: 手順 6、 2の画像 2
    • Place the hard drive in the hard-drive bracket.
  7. Dell Inspiron 10z 1120 Hard Drive Replacement, Replace the Screws: 手順 7、 1の画像 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 10z 1120 Hard Drive Replacement, Placing the Hard Drive: 手順 8、 1の画像 1
    • Place the hard-drive assembly in the computer base.
  9. Dell Inspiron 10z 1120 Hard Drive Replacement, Replace the Two Screws: 手順 9、 1の画像 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
終わりに
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,555 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 26
今までの合計 407
