メインコンテンツにスキップ
Dell Inspirion 15z-5523 Hard Disk Drive Replacement
必要な工具と部品
  1. Dell Inspirion 15z-5523 Hard Disk Drive Replacement, Hard Disk Drive (HDD): 手順 1、 1の画像 1
    • Pop out the rubber pieces and unscrew the 7 screws on the bottom of the computer.
    • Open the RAM door in the center remove the hidden screw labeled "KB" just above the RAM sticks.
  2. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 手順 2、 1の画像 1
    • Using a nylon spudger, push the retaining clips away from the keyboard - there are five along the top row, and two on each side. You can carefully pull the keyboard away from each clip when it's released. The bottom edge of the keyboard will just pull away.
  3. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 手順 3、 2の画像 1 Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 手順 3、 2の画像 2
    • There are two ribbon cables securing the keyboard - data and backlight power. Each ribbon connector must be released by flipping the black retainer up with a fingernail or nylon Uspudger before pulling out the ribbon.
    • First flip up the black retainer on the smaller connector. Slide the cable up and out of the connector.
    • Secondly, flip the black connector up on the larger connector. Slide the cable straight out of the connector, parallel to the case.
    • Remove the keyboard from the case.
  4. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 手順 4、 2の画像 1 Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 手順 4、 2の画像 2
    • Unscrew the surface under the keyboard and remove top plate from the base.
  5. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 手順 5、 2の画像 1 Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 手順 5、 2の画像 2
    • Take the battery out by unscrewing the 5 screws and pulling straight off.
  6. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 手順 6、 1の画像 1
    • Remove the hard drive.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Christian Chavez
メンバー登録日: 01/23/18
729 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G5, Virtue Spring 2018 Western Carolina University, Team S1-G5, Virtue Spring 2018人のメンバー
WCU-VIRTUE-S18S1G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 22
今までの合計 3,473
