はじめに
If your Dell Inspiron 3542 laptop has stopped working or needs to be upgraded with a new motherboard, this guide will help you do so. The motherboard is responsible for system stability and performance, and your laptop will load a lot faster. If the motherboard stops working, then the entire system will begin to fail, including fans, lights, and more.
Before beginning, it is highly recommended to power off the laptop and disconnect the power supply before starting. This can prevent short circuits and other damages.
必要な工具と部品
Slide the latches on both sides of the laptop outward to unlock the battery.
Remove the battery from the computer.
To reassemble your device, follow these instructions in reverse order. Congratulations on replacing the Motherboard on your Dell Inpiron 3542.
5 の人々がこのガイドを完成させました。
1件のガイドコメント
Anyone know where I can purchase a board for a Dell Inspiron 3542 in the UK?
