メインコンテンツにスキップ
Dell G15-5511 Gaming Right SSD (Slot 2) Replacement
必要な工具と部品
  1. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unfasten the back cover: 手順 1、 2の画像 1 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unfasten the back cover: 手順 1、 2の画像 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws in securing the cover.
    • Use a Phillips #1 screwdriver to loosen the four captive screws.
  2. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unclip the front corners: 手順 2、 2の画像 1 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unclip the front corners: 手順 2、 2の画像 2
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement: 手順 3、 2の画像 1 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement: 手順 3、 2の画像 2
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: 手順 4、 3の画像 1 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: 手順 4、 3の画像 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: 手順 4、 3の画像 3
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: 手順 5、 3の画像 1 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: 手順 5、 3の画像 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: 手順 5、 3の画像 3
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  6. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: 手順 6、 3の画像 1 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: 手順 6、 3の画像 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: 手順 6、 3の画像 3
    • The right SSD slot has two locations install the standoff bracket—one for the short M.2 2230 SSD, and one for the longer M.2 2280 SSD.
    • Use the flat end of a spudger to press the the bracket into the slot. The wings of the standoff will clip underneath the tabs of the slot.
    • Slide in the standoff edge of the bracket first.
  7. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Insert the SSD: 手順 7、 2の画像 1 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Insert the SSD: 手順 7、 2の画像 2
    • Grip your 80 mm-long (M.2 2280) SSD by the corners near the screw indent.
    • Slide the SSD into the socket.
  8. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Fasten the SSD: 手順 8、 2の画像 1 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Fasten the SSD: 手順 8、 2の画像 2
    • Use your Phillips #0 screwdriver to fasten the 4.2 mm-long screw to the SSD standoff.
終わりに
To reassemble your Dell G15, follow these instructions in reverse order.
For general information on how to install a SSD, refer to this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
作成者
2人の作成者と共同で作成されました。
Clay Eickemeyer
メンバー登録日: 09/19/22
21,776 ポイント
175のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
137 メンバー
17,055のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 45
過去 30 日: 212
今までの合計 894
