メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell E193FPc Interface Buttons Replacement
必要な工具と部品
  1. Dell E193FPc Interface Buttons Replacement, Stand: 手順 1、 1の画像 1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
    FixBotに聞いてみる
    コメントを追加
  2. Dell E193FPc Interface Buttons Replacement: 手順 2、 1の画像 1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
    FixBotに聞いてみる
    コメントを追加
  3. Dell E193FPc Interface Buttons Replacement, Display Bezel: 手順 3、 2の画像 1 Dell E193FPc Interface Buttons Replacement, Display Bezel: 手順 3、 2の画像 2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
    FixBotに聞いてみる
    コメントを追加
  4. Dell E193FPc Interface Buttons Replacement: 手順 4、 2の画像 1 Dell E193FPc Interface Buttons Replacement: 手順 4、 2の画像 2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
    FixBotに聞いてみる
    コメントを追加
  5. Dell E193FPc Interface Buttons Replacement: 手順 5、 3の画像 1 Dell E193FPc Interface Buttons Replacement: 手順 5、 3の画像 2 Dell E193FPc Interface Buttons Replacement: 手順 5、 3の画像 3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
    FixBotに聞いてみる
    コメントを追加
  6. Dell E193FPc Interface Buttons Replacement, Interface Buttons: 手順 6、 1の画像 1
    • Behind the front panel of the plastic cover lies the button strip.
    • Remove the buttons by gently pulling up on the strip.
    • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Charley Grove
メンバー登録日: 10/10/11
101 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 5-36, Amido Fall 2011 Cal Poly, Team 5-36, Amido Fall 2011人のメンバー
CPSU-AMIDO-F11S5G36
4 メンバー
12のガイドは作成済み
1件のガイドコメント
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 37
今までの合計 2,666
