メインコンテンツにスキップ
Dell Dimension 4600 Video Card Replacement
必要な工具と部品
  1. Dell Dimension 4600 Video Card Replacement, Side Panel: 手順 1、 1の画像 1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Video Card Replacement: 手順 2、 1の画像 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Video Card Replacement: 手順 3、 1の画像 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 Video Card Replacement, Video Card: 手順 4、 1の画像 1
    • Lay the computer flat so that you are looking down on all of the components.
  5. Dell Dimension 4600 Video Card Replacement: 手順 5、 1の画像 1
    • Locate the Video Card and the screw attached to the Video Card as shown in the picture.
  6. Dell Dimension 4600 Video Card Replacement: 手順 6、 1の画像 1
    • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
  7. Dell Dimension 4600 Video Card Replacement: 手順 7、 1の画像 1
    • Push down on the green clip located by the bottom right corner of the video card while simultaneously pulling the card up with your other hand.
  8. Dell Dimension 4600 Video Card Replacement: 手順 8、 1の画像 1
    • Pull the remainder of the card up and out of it's slot.
終わりに
9 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Arvind
メンバー登録日: 10/12/11
395 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S6G10
4 メンバー
11のガイドは作成済み
2 件のコメント
I have a question - My dell dimension 4600 has lines going down the screen, ive tried 3 different monitors, reinstalling windows (reinstalling would have lines going down the screen, after installing all programs the system freezes up with lines going down the screen nothing else) ive tried system restore can someone tell me whats going on?
Don't hurt the chickens - 返信
That sounds like either a GPU failure or internal Graphics failure. Have you checked thermal paste?
William Morgan - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 21
今までの合計 7,639
