メインコンテンツにスキップ
Dell Dimension 2300 Hard Drive Replacement
必要な工具と部品
    • Shut down the computer through the Start menu.
    • Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
    While i switch on computer not start. Does it have fuse inside? Shall i check it first?
    Daniel Hailemariam - 返信
    • Remove the bracket-securing screw, and then remove the drive bracket from the computer.
    • Remove the hard drive-securing screw, and then remove the hard drive from the bracket.
    • Install the new hard drive in the bracket. Place the hard drive in the bracket so that the two screw-hole tabs insert into the two screw holes on the hard drive, and then secure the drive to the bracket with the screw that you removed.
終わりに
7 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
James Walker
メンバー登録日: 10/04/17
368 ポイント
1ガイドが承認済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
2 Guide Comments
Some pictures would be nice.
guardian10 - 返信
No power arrived while i switch on the button of compiutor
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 140
今までの合計 2,527
