メインコンテンツにスキップ
Dell Desktop Optiplex 960 RAM Replacement
  1. Dell Desktop Optiplex 960 RAM Replacement, RAM: 手順 1、 1の画像 1
    • Back up all files and shut the computer down safely.
  2. Dell Desktop Optiplex 960 RAM Replacement: 手順 2、 2の画像 1 Dell Desktop Optiplex 960 RAM Replacement: 手順 2、 2の画像 2
    • Carefully unplug the cords located at the back of the computer (i.e. Power, Monitor, USB, etc).
    • Switch off the electrical connection before unplugging any cords to avoid electric shock.
  3. Dell Desktop Optiplex 960 RAM Replacement: 手順 3、 1の画像 1
    • Pull the trigger located at the bottom of the desktop to unlock the desktop back. This may look different on each individual's computer.
  4. Dell Desktop Optiplex 960 RAM Replacement: 手順 4、 1の画像 1
    • Gently lift up the side panel by pulling it upward while holding the trigger.
  5. Dell Desktop Optiplex 960 RAM Replacement: 手順 5、 2の画像 1 Dell Desktop Optiplex 960 RAM Replacement: 手順 5、 2の画像 2
    • To unlock the RAM, press down the two clips/buttons located on both end of the RAM holder.
  6. Dell Desktop Optiplex 960 RAM Replacement: 手順 6、 1の画像 1
    • Unplug the RAM from the slot.
  7. Dell Desktop Optiplex 960 RAM Replacement: 手順 7、 1の画像 1
    • Ensure that your new RAM chip matches the same shape as the one you removed from your computer.
  8. Dell Desktop Optiplex 960 RAM Replacement: 手順 8、 2の画像 1 Dell Desktop Optiplex 960 RAM Replacement: 手順 8、 2の画像 2
    • Place the new RAM chip into the slot and gently press it down until the clips on either side clasp around it.
  9. Dell Desktop Optiplex 960 RAM Replacement: 手順 9、 1の画像 1
    • Press the wall of the computer back into place until you hear a click from the lock engaging.
  10. Dell Desktop Optiplex 960 RAM Replacement: 手順 10、 2の画像 1 Dell Desktop Optiplex 960 RAM Replacement: 手順 10、 2の画像 2
    • Plug the cords back and power on your computer.
    • Your computer should be back up and running.
終わりに
After completing steps 1-12, your PC will be up running successfully. If the see your computer is still showing issues, repeat the instructions carefully. However, if the device is still not running properly, the problem is associated with the hardware (RAM), which is not considered for this guideline.
作成者
4人の作成者と共同で作成されました。
Mercedes Carter
メンバー登録日: 03/03/20
181 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S2-G2, Lane Spring 2020 University of Memphis, Team S2-G2, Lane Spring 2020人のメンバー
UM-LANE-S20S2G2
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 19
今までの合計 757
