メインコンテンツにスキップ
Dell Chromebook 3100 (Touch) Motherboard Replacement
必要な工具と部品
  1. Dell Chromebook 3100 (Touch) Motherboard Replacement, Detach Bottom Cover: 手順 1、 2の画像 1 Dell Chromebook 3100 (Touch) Motherboard Replacement, Detach Bottom Cover: 手順 1、 2の画像 2
    • Unscrew the nine PH#0 captive screws on the bottom of the device.
    • Use a pick to run along the outside of the device popping all the clips. Prying should not be necessary.
  2. Dell Chromebook 3100 (Touch) Motherboard Replacement, Motherboard: 手順 2、 2の画像 1 Dell Chromebook 3100 (Touch) Motherboard Replacement, Motherboard: 手順 2、 2の画像 2
    • Disconnect the daughterboard data cables.
  3. Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 3、 2の画像 1 Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 3、 2の画像 2
    • Pull the daughterboard power cable out of its socket parallel to the motherboard.
  4. Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 4、 2の画像 1 Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the M2x3 screw and cover, and disconnect the antenna cables.
    • Note: be careful on reassembly. Antenna connectors can be troublesome and are easy to damage.
  5. Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 5、 1の画像 1
    • Disconnect the touchpad, keyboard, nad speakers where shown.
  6. Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the four M2x4 screws, as well as the cover over the LVDS cable (top right).
  7. Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 7、 2の画像 1 Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 7、 2の画像 2
    • Detach the LVDS cable.
    • The cable is held down with adhesive. Don't be shy about pulling it off the motherboard.
  8. Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 8、 1の画像 1
    • Lift the motherboard out from the left side and pull away from the body of the chromebook.
    • During reassembly, it is much easier to insert the motherboard without the IO shield attached. The IO shield is easily inserted after the motherboard is in place.
  9. Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 9、 2の画像 1 Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 9、 2の画像 2
    • Apply lateral force to the IO shield to break the adhesive holding it to the motherboard.
    • Save this IO shield to put on the new motherboard.
  10. Dell Chromebook 3100 (Touch) Motherboard Replacement: 手順 10、 1の画像 1
    • During reassembly, make sure to include a thermal pad on the CPU. Usually you can reuse the one from the previous motherboard, but it's best to have access to a new pad in case the old one is not usable.
終わりに
作成者
1人の作成者と共同作成されました。
Isaac
1,095 ポイント
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 480
