メインコンテンツにスキップ
Dell Chromebook 13-7310 Motherboard Replacement
必要な工具と部品
  1. Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: 手順 1、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Motherboard Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Motherboard Replacement, Battery: 手順 3、 1の画像 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Motherboard Replacement: 手順 5、 1の画像 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Motherboard Replacement, Network Card: 手順 6、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement, Network Card: 手順 6、 2の画像 2
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Motherboard Replacement: 手順 7、 1の画像 1
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Motherboard Replacement: 手順 8、 1の画像 1
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
  9. Dell Chromebook 13-7310 Motherboard Replacement, Motherboard: 手順 9、 1の画像 1
    • Gently pull to unplug fan connector.
  10. Dell Chromebook 13-7310 Motherboard Replacement: 手順 10、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement: 手順 10、 2の画像 2
    • Remove 4 screws securing heat sink.
  11. Dell Chromebook 13-7310 Motherboard Replacement: 手順 11、 1の画像 1
    • Lift away heat sink.
  12. Dell Chromebook 13-7310 Motherboard Replacement: 手順 12、 1の画像 1
    • Remove the eight 2mm screws securing the motherboard in place.
  13. Dell Chromebook 13-7310 Motherboard Replacement: 手順 13、 1の画像 1
    • Release cable for the LED charging indicator by pulling up on connector.
  14. Dell Chromebook 13-7310 Motherboard Replacement: 手順 14、 1の画像 1
    • Gently remove the cable.
  15. Dell Chromebook 13-7310 Motherboard Replacement: 手順 15、 1の画像 1
    • Pull up on connector tab to release IO board cable.
  16. Dell Chromebook 13-7310 Motherboard Replacement: 手順 16、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement: 手順 16、 2の画像 2
    • Pull up on connector tab to release touchpad cable.
  17. Dell Chromebook 13-7310 Motherboard Replacement: 手順 17、 1の画像 1
    • Release the keyboard backlight cable.
  18. Dell Chromebook 13-7310 Motherboard Replacement: 手順 18、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement: 手順 18、 2の画像 2
    • Release the keyboard cable.
    • If taped to the motherboard, gently peel it off.
  19. Dell Chromebook 13-7310 Motherboard Replacement: 手順 19、 1の画像 1
    • Release eDP cable.
  20. Dell Chromebook 13-7310 Motherboard Replacement: 手順 20、 1の画像 1
    • Release dc-in cable.
  21. Dell Chromebook 13-7310 Motherboard Replacement: 手順 21、 1の画像 1
    • Gently lift up the motherboard to remove it.
終わりに
作成者
4人の作成者と共同で作成されました。
Brett Raymond
メンバー登録日: 11/01/18
469 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018人のメンバー
UMASSD-GULBRANDSEN-F18S5G1
3 メンバー
5のガイドは作成済み
コメント 1 件
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
Jeremy Ryan Terrence - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 8
今までの合計 929
