メインコンテンツにスキップ
Dell Chromebook 11-3120 Speakers Replacement
必要な工具と部品
  1. Dell Chromebook 11-3120 Speakers Replacement, Back Panel: 手順 1、 2の画像 1 Dell Chromebook 11-3120 Speakers Replacement, Back Panel: 手順 1、 2の画像 2
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Speakers Replacement: 手順 2、 2の画像 1 Dell Chromebook 11-3120 Speakers Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
  3. Dell Chromebook 11-3120 Speakers Replacement, Battery: 手順 3、 2の画像 1 Dell Chromebook 11-3120 Speakers Replacement, Battery: 手順 3、 2の画像 2
    • Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
  4. Dell Chromebook 11-3120 Speakers Replacement: 手順 4、 1の画像 1
    • Using the pointed end of a #2 spudger, remove the connection between the battery and motherboard by slightly pulling on the wires while pushing the tiny hole down using the spudger.
    • Pull out the battery from inside the laptop.
  5. Dell Chromebook 11-3120 Speakers Replacement, Speakers: 手順 5、 1の画像 1
    • Gently remove the 4-pin connector that connects the speakers to the motherboard.
  6. Dell Chromebook 11-3120 Speakers Replacement: 手順 6、 1の画像 1
    • Remove the tape securing it to the plastic casing of the device.
  7. Dell Chromebook 11-3120 Speakers Replacement: 手順 7、 1の画像 1
    • Carefully lift out the right speaker housing, which is held in place by circular rubber guides, located on both sides of the housing.
  8. Dell Chromebook 11-3120 Speakers Replacement: 手順 8、 1の画像 1
    • Moving down the cable, remove the left speaker housing, which is held in place by circular rubber guides, located on both sides of the housing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Joseph Silveira
メンバー登録日: 10/19/17
401 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G1, Julie Fall 2017 UMass Dartmouth, Team S4-G1, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S4G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 398
